Using the latest CNC machines, Xometry produces highly accurate, quick turn parts in as fast as 1 day.
CNC Machining is perfect for production of 1-10,000 parts.
Offers high-precision tolerances ranging from +/-0.001″ – 0.005″, depending on customer specs.
Choose from over 50 metal and plastic materials. CNC Machining offers a wide variety of certified materials.
Select from a variety of finishes on solid metal parts, built to precise design specifications.
Because CNC Machining services can be applied to virtually any material, it is perfect for rapid tooling, i.e., creating fixtures or molds.
The range of materials available, low cost per unit, and speed of production makes quick turn CNC a great option for prototyping.
High-quality finish, vast material options and precise tolerances have made CNC machining a favorable technology for end-use parts.
Xometry is your one-stop shop for manufacturing on demand. Xometry offers 24/7 access to instant pricing, expected lead times and manufacturability feedback. Xometry’s nationwide network of 2,500+ partner manufacturing facilities guarantees consistently fast lead times across a broad array of capabilities, including CNC Machining, 3D Printing, Sheet Metal, Urethane Casting, Injection Molding, Extrusion, Die Casting, and Metal Stamping.
©2018 Xometry | ITAR Registered
